1793
- Louisville, Kentucky
- Inspector
I received a call the other day from a customer informing me that they had lost power. They had called the POCO before calling me. The POCO came out and according to the HO they pulled the meter and placed a "load" on the system at the meter, and reported that everything was fine. The workmen told the HO to call their electrician to check out the problem.
The panel is a Federal Pacific split buss with a 50 amp main for the lighting. It appears that the power loss is not the entire house and when it goes off it comes back on, on its own.
I checked all of the ungrounded conductor connections in the panel and all were tight, I took readings as well at each and every breaker and all appear to be working correctly. I checked the connections at the meter as well and all were tight. Power appears stable for a few days then, winks off, and back on.
I have thought about changing the Main breaker but I don't want to start jumping hoops if I don't have to. Do I call the POCO back and if so what should I ask them to do or check?
I'm looking for any suggestions about how I might find the cause of this problem.
