I did not know
EC - retired
I use CH almost everywhere. I bought 100 amp main breaker panel for a rural shop building. I frequently use a ML panel and back feed a 100 or 70 or 90 CB but the 100MB with plug on neutral was less expensive. Nice until you go to put a 2 pole GFCI in for Air Compressor receptacle. They don't fit and CH doesn't make a plug on style. Huh??:jawdrop:.
The only solution is to set a small sub next to the brand new panel. :thumbsdown:
I also use CH and the plug on neutral panels are the only style my supply house carries, are you saying all GFI breakers wont fit?
Tried some CH-CH loadcenters a few years ago for one of our farm customers new offices. The breakers kept popping off the buss.
Tried a CH CH metermain for an overhead service. Couldn't flip the line side lugs for a top feed like Siemens, had to chase overhead wires down behind the jaws and curl back up into the lugs. Was a total pain in the ###.
No more CH for me.
