After seeing the argument about extra SA circuits being added to the feeder/service load calculation or not, I have a couple observations.
The code is not clear one way or the other, so the only correct answer is that it doesn't say. People were asking Mike to prove his position using only the code, when the other position also cannot be proven with only the code.
People were generally on one side against Mike, and a similar thing happened in this thread. The interesting observation is this thread while a different subject, has the SAME basic flaw in the code. Are the "extras" subject to some other rule or not? Some of the people that said NO in the SA load issue, said YES in the above thread (do extra receptacles beyond what are required need to be on the SA circuit).
My personal opinion for what it's worth, for the SA load, I can see both sides argument, but in general I think if you put in extra SA circuits, it is because you think there is more load than two can handle. It seems bad to me for the code to accept 2 circuits no matter how large the house is. On the older thread, I don't see the other side at all. To me to allow extra 15A receptacles between the required 20A ones is rediculous.
Sorry if any of this was mentioned already. I didn't have time to read everything in the thread.
