petersonra
- Northern illinois
- Semi-retired engineer
big feeder - 2500A or so.
there is no real reason that it has to terminate at a CB as was originally envisioned.
If I were to find something else to terminate it at that joined all the conductors together it is just a normal parallel conductor feeder.
Then I can tap off to two 1200A CBs.
is there anything that I can use to tie those conductors together and tap off of?
no distribution blocks in that size.
i looked at lugging it to 'something" but that something is missing.
this cannot be a unique situation that no one else has ever run across before. there must be a simpler solution that I am just not seeing.
I can't see using a 2500A CB as a distribution block.
