LouisianaApprentice
- Forest Hill, LA, USA
I'm new to the forum sorry if this question is in the wrong section. I tried searching but couldn't find an answer for my question. My question is with resistive loads when you add voltage how can you calculate amperage drop if there even is any along with heat output. What made me think of this is when you have a 480v heating element (my employer recently changed out 2 cooling towers) the load should still be the same right whether 277 or 480 the output would just be different? Or is it just that these types of elements are really just 3 with a phase tapped into each one which I cannot see as there was no required neutral so I have no idea how voltage would return.
So let's say it's a 1500w resistive load would this load be divided over the three legs (which I couldn't see) or would u divide by the voltage to find wire sizing. Also would it be negligible the amount of resistance decreased from 277 to 480 to reduce amperage. Sorry Im kinda just trying to wrap my head around resistance loads.
