ran into something odd i had 18 amps on a ground connection in a house.the house was turn into two apts . the electrician who did the upgrade from from
the fuse box to circuit breakers never ran outside ground rod and didn't run a ground wire to the water meter.instead they ran a ground wire to water heater
which is right near the panel. told landlord that has be correct first!!!next i didn't find the circuit that was causing the feed back because i couldn't get in the upstairs space.i thick it could be ac window unit causing the problem or a back feed on from a neutral from a circuit because all hot wire were reading low amps.even turn off main breaker to main panel then the ground to water pipe read 7 amps. i think that there a back feed somewhere.and i think that circuits from the first floor go to second floor this one is old it will take time to trace. any idea anyone?
