aelectricalman
- KY
I want to share it with everyone so you can all take it on a test run but I cannot upload an excel file. Anyone know a way to do that?
Place the file on some host site and put a link to it in your post. Could be your own website if you have one or anyplace you can dream of placing it.I want to share it with everyone so you can all take it on a test run but I cannot upload an excel file. Anyone know a way to do that?
On that note, I have to wonder whether the forum server checks for valid file type when uploading...?Have you tried just giving the file a .PDF extension?
Excel and word files can very very easily host a virus and/or worm, I never download them off of websites.On that note, I have to wonder whether the forum server checks for valid file type when uploading...?
What I have done in the past is embed the Excel file in Word file.
Otherwise you can host it on a file sharing service and just include a link to it.
I did not say to embed it in a PDF, I said to rename it with a .pdf extension.Its an excel spreadsheet so it has to be able to perform calculations.
PF savings calculator? Why?
1) Call your PoCo and get your tariff structure
2) See if it includes a penalty for PF. If no, you are done. Zero savings.
3) If yes, what is the PF penalty point? If, like here in California where it is .75, then there is a 99% change you are fine, meaning no savings because you are not getting penalized. Same as #2.
4) If your penalty threshold is .95 or under, find your largest inductive loads and correct their PF with caps, keep doing it until PF goes better than .95. Penalty avoided is savings.
Then anybody who downloaded it could just rename it, virus check it, and run it.
Embedding it in a Word file would limit your audience to those using IE and/or having a copy of Office. (Not actually quite that bad, but more difficult to sort out.)
As alluded to, it will not work if the forum ( or other website) software does a deep dive into the file to detect its real application type. I do not think this forum does that.Interesting... I did not know that could be done! thanks.
Have you ever read many of that members posts? Won't say he has never been wrong, but he is hard to stump. But keep picking his brain - this could be good entertainmentWell aren't you a Debbie downer sir!
1.) Its for private industry to use. My intention for this calculator is so I can go into a facility arms and loaded. have you ever worked with a Utility? If you have, you would understand that nothing gets done in a hurry and nothing gets done without going through the customer first. If Im trying to sell my product, I want my potential customer to have some information at hand to decide if they want to continue to talk to me.
2.) Its not that easy my friend. There are so many factors that play into PF penalties. Those include time of day, ratchets, some have KVA savings, some have KVAr savings, some have kW savings with 90% PF penalty.
3.) Here in KY, I had a customer with a 91% PF penalty. I took them up to 99% and saved them $134,000 the first year ( and every year after). You Californians are losing out, it sounds.
4.) I understand that sir. This is why I need a calculator. With a calculator you can justify the savings. There is a lot more to power factor correction than installing equipment.
Lol...Well aren't you a Debbie downer sir!
Pretend I'm a "customer".
Q1: Why should I use your pf calculator instead of Eaton's online calculator?
Q2: Why is yours better than the other calculator's on the market?
Q3: How do I know I can trust the results; since you're obviously trying to sell me something?
Q4: Are you going to guarantee me the savings that your calculator says I should get?
Just as a side point - IMO, the facilities that have a potential to really save anything are probably big enough that they have an on going relationship with an engineering firm that they trust. To get them to buy-in you would need to build a relationship with that manager, and then sell them on why your offering is better.
