justdavemamm
 - Rochester NY
Now when you don't/can't have 2 inches of separation between I.S. and non I.S. circuits, you can use 20 gauge sheet metal between then per 504.30, FPN.
504.30 (A)(2) Exception No.1 lets me also separate them (when closer than 2") by ..."approved insulation partition."
Anyone know of a such partition ? Or what defines it ?
I've got a case where there are I.S. devices (PB's & LED LT's) mounted on the door of a panel and when the door is closed, the wire loops / connection points coming off them are about 1 3/4" away from wires & devices mounted on the back panel of the enclosure. Cannot make it further away.
Unfortunately, the enclosure isn't big enough to get inside and measure precisely, so were doing that by measuring offsets from reference points.
I could take some 2 ft x 2 ft sheet metal and mount in over the wiring inside the door. But that would add screw holes to the door, as none are there now. And look terible.
Or I could do the same inside the enclosure, mounting the sheet metal over the components.
I'd like to use something other than sheet metal. Any thoughts.
BTW, next time this machine is built, I'm going to get a deeper enclosure.
Tx, Dave
Tx, Dave
