I was watching mike holts video on stray voltage
zappy
CA.
I was wondering about the equalpotional plane. If you bring everything to the same voltage, and lets say theres 3 volts on it all. Then you step off of it and now one of your feet is on the equalpotional plane, and one of them is on the ground wouldn't you get shocked?
Not by 3 volts, necessarily, but yes, there is a step-potential risk. That's why pools require the mesh a certain distance from the rim, and I believe sub-station ground mats have a similar requirement.
Tis would depend on if the source was somehow bonded to ground . If not bird on a wire scenario.
This is not nearly as much a concern from "mesh to ground" as it is from "pool to mesh" so to speak. The intent of the EPBG is to raise the voltage within the plain to the same potential but once you leave the "grid" area to the lets say ground the step potential is not of the same concern as you would have around the contour of the pool in this example.
If that even makes sense....;)
To prevent this same problem affecting cattle the answer is a gradient ramp
