Im doing some research on a failed inspection. The inspection notes do not reference the NEC, but instead reference the IBC, Electrical chapter which I assume is very similar to the NEC.
The inspection comment says;
"E3406.11.3 Length of conductor for splice or termination.
Where conductors are to be spliced, terminated or connected to fixtures or devices, a minimum length of 6 inches (152 mm) of free conductor shall be provided at each outlet, junction or switch point. The required length shall be measured from the point in the box where the conductor emerges from its raceway or cable sheath. Where the opening to an outlet, junction or switch point is less than 8 inches (200 mm) in any dimension, each conductor shall be long enough to extend at least 3 inches (75 mm) outside of such opening."
Does anyone know if this requirement appears in the NEC? Im assuing this is saying that a minimum of 6" of slack shall be provided for every receptacle & luminaire or other similar junction.
Any thoughts would be appreciated.
