I was going over some of my "favorites" and re-discovered the site MDShunk posted awhile back with the video tips at ibewhourpower.com.
I'd like to submit a tip to win a prize but I am not an IBEW member (required), so I will just share it with you and if one of you IBEW guys wants to submit it go ahead.
This one is mostly for the residential guys. If you need to cut in a box and can/must feed it from below it can be hard to find the wall cavity sometimes, or hard to find exactly where you need to drill. Can't drill a small pilot hole next to the wall into the floor below if it is carpeted because the carpet will almost undoubtedly ball up on the drill and tick off Mr. and Mrs. Homeowner, not to mention 3" or so of a small bit can still be hard to see in a crawl space.
Or can you?
Cut the bottom "straight" length off a wire coat hangar. Make one cut at a sharp angle and chuck the other end into your battery drill. Drills right through carpet without balling and zips right through the subfloor and into the basement or crawl space. This give you a very easily identifiable location. Go into the basement or crawl and back off 1 3/4" from the coat hangar and drill the hole for your romex right into the center of the wall cavity. Works good.
This may be common knowledge and if so, sorry, but I learned it years ago and most guys I've shared it with hadn't heard it before.
Or can you?
