Rumor has it that I am unable to install Halo IC rated recessed fixtures in my garage ceiling (TGI joists supporting living space above) in spite of the fact they will be entombed in Roxul. 5 1/2 inches of Roxul above, 11 inches on each side of new work housing, and ceiling rocked with 5/8 Code X drywall. Roxul is non-combustable, has no smoke penetration, and melts down at 2150 degrees. Fixtures will be fed by branch circuit via Arc Fault breaker. Am I missing something here? Why would this not be allowed. i know about the other products out there, .... one of the products is 3/4 of an inch thick and is rated for 475 degrees. It is a form of sheet material made of the same material as Roxul. I'm seeking comments on my installation (the entombment method I outlined above). Roxul is not UL listed or listed by another similar agency. Pehaps this is the issue leading to my installation being frowned upon?
Thanks
Thanks
