IC recessed lights
Greg1707
Alexandria, VA
Business owner Electrical contractor
I have a job where the batt insulation has already been installed between the ceiling joists. The GC said to just cut a hole in the insulation to accommodate the IC rated cans. It would seem this would leave the light fixture uninsulated and the vapor barrier will be compromised.
Is this best practice?
If the fixture was installed first and the insulator cut the insulation around the fixture the vapor barrier would be cut anyway so I don't see that as an issue. I would guess that the energy code would have something to say about the top of the fixture having to be covered with insulation.
I've seen articles in Fine Homebuilding &c about building a box out of insulating foam to perch over the cans on the attic side. But only if the cans are 'insulation-touching' rated.
