Nick99
- Brookport, IL
I have taken the ICC test for MO. I got a 74 and requires a75 to pass. One of the questions on the test that I’m not sure if I got right or not is as follows. Where should the disconnect be installed for a outside heat and AC unit be. The answer I remember were A. accessibly and lockable B.50feet C. 25feet D.6feet I chose A. Everything I find just says insight and if not lockable. This was on the test in two different questions I never found a distant listed the test is on 2014 code.
