I have a relay with a 24 volt coil. Does anyone know if the coil is typically rated to be energized constantly. I know that there are ways to do what I want with electronics, but I am using what I have. I am making a local door alarm that is to be used as a deterrent from students going out a door that their only suppose to use in case of a emergency. There we be a buzzer that goes off when the door is open and only sound locally. So I have a set of contacts that are closed when the door is closed. When the door opens the contacts at the door will open. I was wondering if I could wire the coil of the relay so that it would be energized when the door is closed and deenergized when the door is opened. This is not for security! I am also using a universal timer also so the buzzer only goes off for so many seconds. Please respond only if you know or if you have a better way of accomplishing this with what I have. I know that I could use a set of door contacts that are just the opposite but if a wire was removed it wouldn"t alarm.
Thank You
Thank You
