Ics Electrical Inspector License Nj
mreal
I pass the 2A test for electrical inspector nj, four years ago, and i will take the 2B next moths, for get a ICS license ( 2A and 2A test is req.). Do i need retake the 2A test again, or i need CEU credits.because it expire 1 year ago (2A TEST) (is VALID only for 3 years)
Max
celtic
NJ
Max
I can't answer your question Max, but I may be able to point you in the right direction:
http://www.nj.gov/dca/codes/licensingunit/pdf/licensing_info_booklet.pdf
All inquiries concerning the licensure of Code Enforcement Officials should be directed to:
Licensing Unit
Bureau of Code Services
N.J. Department of Community Affairs
PO Box 816
Trenton, N.J. 08625-0816
Phone: (609) 984-7834
TDD: (609) 633-6804
Email: codeslicensing@dca.state.nj.us
This booklet is intended to assist in the completion of an application for licensure, and to describe the types of code enforcement licenses available. Specific requirements necessary to obtain a license are found in subchapter 5 of the aforementioned regulations.
EDIT to add another link:
