Abdel Rahman Mohamed
- Riyadh,KSA
one of the most important factors in evaluate the circuit breaker the ratio between ultimate and service short circuit current(Icu,Ics) is there a fixed no of tripping identifying the both values.
I for one have no idea what the terms you are asking about mean. They are not terms that are common in the US.
[h=3]Icu and Ics: essential to operational reliability[/h]Across both categories, circuit breakers must deliver reliability. The two IEC 60947-2 requirements which ensure that reliability are:
? Ultimate breaking capacity (Icu)
? Service breaking capacity (Ics)
Icu is the maximum short-circuit current that a circuit breaker can break without damage. That maximum might be 6,000 or 10,000 amps. Or when it comes to MCCBs, as high as 200kamps. However, in a sense, Icu is essentially as statement of quality for a specific voltage rating.
And that?s where Ics comes in. It is expressed as a percentage ratio of Icu and tells you the maximum short-circuit current if a circuit breaker can break three times and still resume normal service. The higher the lcs, the more reliable the circuit breaker.
It can interrupt more than 3 times, but the official rating will be based on the highest short circuit current that it can interrupt three times without damage.Is it mandatory that circuit breaker will interrupt 3 time only or it can interrupt more than that.
