Background
Background
Mostly industrial electricity. The reason I ask is that when I moved a residential service for my son-in-law's house addition, the service panel became secondary as it was now inside with a disconnect outside, which made the service a secondary panel. The inspector required me to separate the neutral and ground at the service, which unbeknownst to me, is apparently code. Hence my question. If the neutral and ground are not common, then, apparently, the neutral is not a grounded connector...is it? And I have never had a journeyman or master electrician able to explain the reason for this (separation of neutral and ground on secondary panel. Do you know?
Thanks for replying.
