timmermeier
- alton il
- electrician
IDEAL blue wire nuts are rated for al to cu . what makes them different a normal wire nut with noalox on it ? ( are they ul listed )
This Ideal document says otherwise, and this one says the same.IDEAL blue wire nuts are rated for al to cu . what makes them different a normal wire nut with noalox on it ? ( are they ul listed )
What if you add a capped-off copper pigtail? Are there al-to-al wirenuts?The purple is listed for copper to copper and copper to aluminum, but not for aluminum to aluminum.
I guess that would be a copper to aluminum connection. The conductor list shows combinations of two aluminum with one copper.What if you add a capped-off copper pigtail? Are there al-to-al wirenuts?
Did I miss national aluminum wire week or something? Lots of aluminum wire threads lately.
I also posted this in another thread, I'd look into one of these power crimp tools
its like a mini version of what linemen use:
https://www.te.com/usa-en/products/...ing-tools/intersection/retermination-kit.html
Seems like less box space wasted and then you have copper pigtails.
Yeah its unfortunate when the 6" of wire in a box 'rule' was treated more like a suggestion, and if your dealing with a manufactured home its even worse when the box is 8 cubic inches or whatever they got away with.I saw that on aluminum nmb post. Most alum in homes I come across you can’t pull the wire out enough to get that to work
Only ever seen in mobile homes. Never in a manufactured homes, its alway's in single wide trailers park.Yeah its unfortunate when the 6" of wire in a box 'rule' was treated more like a suggestion, and if your dealing with a manufactured home its even worse when the box is 8 cubic inches or whatever they got away with.
Do you often see 12-10 AWG aluminum in homes other than manufactured / mobile homes ?
