does wago make one for aluminum ?
THANK YOU, LIKE ALL GOOD ELECTRICANS YOU DID THE RESEARCH !They say you can use them, but would want to see a listing that says they are suitable for use with aluminum.
WAGO with Aluminum
I did not do all of the research that is required...if you are going to use them for aluminum, you need to verify that they are listed for that purpose.THANK YOU, LIKE ALL GOOD ELECTRICANS YOU DID THE RESEARCH !
While the code language in the parent text of 110.14 stops short of requiring the connector to be listed for that use, I would not use such a connector.I CALLED WAGO USA, THEY SAY YOU CAN USE WAGO FOR ALUMINUM WIRE IF YOU USE THE ALU-PLUS CONTACT PAST, BUT IT IS NOT UL LISTED !
