NYwiregirl
- Warren County, New York
As far as I can locate, it appears the NEC does not specify color coding for current carrying conductors. On 120/240, 120/208, 480/277 systems, there are generally accepted color coding practices for current carrying conductors, which I use religiously... but my next project will be in an old factory building where feeders are a 600 volt delta open conductor/insulator standoff arrangement on the concrete ceiling, and I must provide a tap to a disconnect switch.
As a matter of practice, I'd like to identify phase A, B, and C with proper color 600 volt rated marking tape. Suggestions?
TIA !
TIA !
