joe tedesco
- Boston, Massachusetts
2005 NEC Rule 250.119 Identification of Equipment Grounding Conductors.
Unless required elsewhere in this Code, equipment grounding conductors shall be permitted to be bare, covered, or insulated.
Individually covered or insulated equipment grounding conductors shall have a continuous outer finish that is either green or green with one or more yellow stripes except as permitted in this section.
Conductors with insulation that is green, green with one or more yellow stripes, or identified as permitted by this section shall be used only as an equipment grounding conductor.
[ROP 5?1, 5?220]
Does this new rule make it a violation to use green, or green with a yellow stripe to identify the GEC?
[ July 29, 2003, 08:41 AM: Message edited by: joe tedesco ]
[ROP 5?1, 5?220]
