Jpflex
Electrician big leagues
- Victorville
- Electrician commercial and residential
If a standard residential single split phase system has a service or pannelboard and if a branch circuit is fed by a 2 pole breaker is it true that each ungrounded conductor per pole would not have to be identified or "phased" per pole?
NEC 210.5 C Makes it appear this way. However when the code says a system with one nominal voltage, does this mean they are only considering the 240 vac pole to pole while ignoring the 120 VAC pole to neutral?
I understand multiple systems with different voltages but what about the above?
