Can anyone identify the relay in the photo? (there are actually 3)
The photo is of the low voltage side. It is installed on the side of a panelboard and controls a light circuit (inside the panelboard). The realy pokes through a hole in the side of the panelboard.
Aww, I was gonna say, "Yep, that's a relay, all right!"
There, I said it anyway.(In a good mood; ask me why.)
Naah. Still in the dark on that one.You found out what the strange reputation you have here is?:angel:
That's a relay??Can anyone identify the relay in the photo? (there are actually 3)
...(In a good mood; ask me why.)
That's a relay. Momentary current to open, momentary current to close. Specifically made for low-voltage remote-control residential lighting.That's a relay??
Went on a fundraiser ride today, which included three laps on the track at Richmond International Raceway.Okay, why are you in a good mood Larry?
Went on a fundraiser ride today, which included three laps on the track at Richmond International Raceway. View attachment 23037
https://en.wikipedia.org/wiki/Richmond_Raceway
190602-1446 EDT
olc:
What was the purpose of your question? Has it failed and you need to replace it? Or you want to know how it works? Or just curiosity?
If it is what we assume, then an RR-7 is a suitable replacement, but way overpriced from a distributor.
Even today an RR-7 us an ideal device for many applications.
Those were very reliable and unless you’re adding WiFi control or dimmer, use it. Dimmer could be done with a bit of workThe existing relays control 3 light circuits with 2 sets three-way switches. The lighting is being replaced (including the circuits). It would be convenient to re-use the control.
