Gilf
- Ankara, Turkey
Hi,
Is there anyone familiar with IEC 60079?
I'm designing an aircraft maintenance hangar. Ok, so the hangar space will be zone 1 as per IEC 60079 as I have jet fuel in the building. However, is the only way to determine the extent of zone to do the tedious calculation in the standard? NEC is so much more clear on this. I am so confused as to if I have consider the whole space (up to ceiling) a hazard zone or if there is a way that I can draw a line. For example, as per the NEC I can end the hazardous zone at 450mm above ground level. But I have no idea how I can draw the line according to IEC.
Thanks for any help in advance!
