I want to make sure I understand CE definition of "PROTECTIVE CONDUCTOR TERMINAL" denoted by this:
IEC 61010 defines it as terminal which is bonded to conductive parts of equipment for safety purposes and is intended to be connected to an external protective earthing system. So if I ground the neutral of transformer secondary, the earth terminal is a "PROTECTIVE CONDUCTOR TERMINAL"? But if an equipment case is grounded to a terminal, the terminal is not "PROTECTIVE CONDUCTOR TERMINAL"...
Do I have this right?
thanks,
thanks,
