J.P.
- United States
I am working on a project with ifc walls consisting fox blocks poured full of crappy concrete with river rock in it.http://www.foxblocks.com/products/fox-blocks/
Seems like a simple task to cut the foam away and shoot on a box with a ram set........
The cutting of the foam is simple and quick, its the attaching the box that is not working out.
The concrete blows out when the fastener goes in hits a rock and bends.
I tied 3/4 nails with washers. 1/2 nails with out. Red shot and green shot on various power settings.
2 boxes is secured properly, 15 are ruined. I need to fasten 26 boxes.
I tried the usual tapcon and masonry bit but the river rock in the concrete is too hard for the bits and destroys them. I went thought 5 drill bits and got very few holes drilled.
Maybe I need one of those medium sized hammer drills?
I did use some of the masons 2 part epoxy to attach one box to the wall. It seemed secure, I didn't try to pry it off with a crowbar or anything but I did tug on it with a pair of needle nose and try to wiggle it, felt solid.
Has anybody used epoxy to fasten boxes? Is it an acceptable method.
