Will an IG receptacle serve it's purpose if it's terminated at a sub panel where the grounded conductors and the EG conductors are not seperated? Seems that if it was taken all the way back to the main panel you would have the same scenario with the neutral and E grounds bonded there. Is the intent of the IG to be that there is nothing else on that grounding conductor that would cause "interference". Thanks.
