So I'am working on replacing some flare tip igniters.
The wire which runs to the igniter is a 18AWG, 25kV rated wire which runs from and ignition module/controller then up to the flare. The splice provided by the vendor is a ceramic terminal block with small set screws. The block is mounted in an enclosure similar to a GUAT.
I have a huge concern about this connection as assuring that I can have essentially a connection that will NEVER come loose. If I loose this connect and cant light a flare I'm screwed. l
Any recommendations for a 20AWG, 25kV splice?
