K_Buz
- Southeastern Wisconsin
I found this at a house I was at and just had to take a picture. I always wonder how a contractor gets an inspector to sign off on something like this. (I'm assuming is was inspected because the POCO has its permanent crimp connectors on it.)
Funny that no one seems to worried about the light fixture just hanging there by the wire nuts. Either I'm missing something or I'm not getting a good look at it, but I'm not sure that I see a huge violation.
Those connections are only about 8' above the walkway...and the walkway leads to the front door. Maybe the picture doesn't do it justice, but when you are standing there, you can almost touch the connections.
I just re-looked at the first photo, the second photo looks like it would hit on the rake but in the first photo it looks like it will clear
Bet the drop was there before the deck which is why it is now to low.
If you can "almost" touch it, then it's probably higher than 8'.
Doesn't how tall you are have a big impact on this![]()
