Minuteman
- The Sooner Nation
One of my A/C contractor buddies gave my number to a Realtor that is try to sell a small house. Seems the home inspector is requiring a "permanent heating source" to be installed in the home. A/C guy punts and Realtor has me over to bid installing baseboard heat. I wish I had not left my camera on the bucket truck
The house is only about 800 ft/2 and was newly bricked. The 60-amp meter pan is now recessed into the brick, and the brick surrounds the meter so light that some brick would need to be removed to remove the band that seals the meter. The riser is also behind the brick, and is one of those old time "goose neck" risers. It's a 1" RMC that I believe goes up about 2', to the right about 5', and then back up to the weather head. The conductors look like two #6 TW and one #6 bare.
The panel is a brand new Cutler Hammer BR, about a 12/20 with a 100-amp main. Most of the breakers are labeled in the same foreign language that the residents speak. The service is in a laundry room addition to the home, and has a very low, flat, roof. There is no attic connecting the add on to the home. There is a NM running out of the wall, exposed, to feed the laundry room.
Anyway. The Realtor says, "Just give me a price to install 4' of baseboard heat and a line thermostat. We close on Monday. If you need him to run the wire, he will and You can just hook it up."
I don't need this kinda stuff. Thanks, but no thanks.
