LHarrington
- Saginaw Bay area Michigan
Good afternoon,
Just finished up connecting a new piece of equipment in the plant that requires 240 volt single phase. We purchased a Square D 5kva trans to step down the 480 volt at the buss to 240 required. After all connections are made we energize the 480 all is good, check the secondary off the trans 235v all appears good. Try to energize the equipment nothing! Start troubleshooting find a burnt wire in the slip ring for this equipment. Go back to breaker after the trans find one leg to ground 120v the other is 300v to ground. Check it with a wiggy and nothing happens. Consulted Square D tech support they claim I'm reading phantom volt with my DMM and not to be concerned. Am I missing something. I compared my reading to an identical trans less than 20 feet away and I get 120 to ground both legs. Both trans are wire the same and neither one of the have any of their legs grounded.
LHarrington
LHarrington
