I'm mounting a track lighting track directly flush to the underside of a drop ceiling
catronics
Nevada City, CA
Hi guys - Greetings from Fresno, CA
I'm mounting a track lighting track directly flush to the underside of a drop ceiling. The ceiling tiles are soft and semi-translucent (they're made with a thin white fiberglass fabric shaped into honeycomb-like parallel channels). The corporate project manager sent me photos of steel strut channel resting on/attached to the top of the 1" t-bar, with the lighting track bolted to the bottom, through the ceiling tile.
Why are we doing this this way?
The lighting heads are 3.3 lb. apiece, and there are 2 or 3 of them per 4-linear-foot length of t-bar, for a weight of 6.6 to 10 lbs. The guys who did this in Georgia seemed to think the strut was necessary. Is it? Can we use t-bar clips, like the ones from Caddy or Griplock, without the strut channel? Would it be earthquake-safe enough? Is 10 lbs. per 4 ft. length okay?
It sure would save a whole lot of time.
LarryFine
Henrico County, VA
Electrical Contractor
I would check the T-bar and clip makers for weight ratings, and strive to attach to main runners, not 2' or 4' T-bars.
Sierrasparky
USA
Electrician ,contractor
You need independent support , usually done with support wires. Use the caddy's with the loop for a support wire.
catronics
Nevada City, CA
There's no way I can get to that ceiling. I's ten feet above the drop ceiling, and this is a retrofit for an operating business. Can I hitchhike onto the existing wires? It's only a maximum of 10 lbs. per 4 ft. of track.
catronics
Nevada City, CA
P.S.
P.S.
The lighting track must be flush up against the bottom of the drop ceiling. This keeps it from torquing from the cantilevering of the light heads.
30W - 2.9 lbs. each (corrected weight)
catronics
Nevada City, CA
We have MC cables coming into these track runs, and they are very securely attached to those support wires with "bat wings." That will keep at least one end of the track secure against earthquake, I believe. Now we're daisy chaining the tracks together, which means there's an MC cable at each end, which means that it would be supported at each end. We are still experimenting with what will work.
cowboyjwc
Simi Valley, CA
What he said.
shopping
