mmm ... braniacs
mmm ... braniacs
Here is a good video about electric fences. If you are isolated from the earth, offering no path back to the source, no shock.
http://www.youtube.com/watch?v=-n1pSHzdahc
I actually did that experiment in high school, freshman year IPS, Introductory Physical Science.
The teacher was out of the room and the guys had found this mini high voltage generator. It looked like a hand held hair clipper, plugged into 120 VAC with a lamp cord, and drew a 1" arc to metal.
I looked over and the guys were zapping the aluminum blackboard rail and touching the rail ten ft. away, they felt nothing.
I knew it was because the circuit path was open, they were not in the load path.
I told them they had to touch the rail and the cold water pipe at the same time, then they would get it.
It took four or five guys to reach, hand to hand, from the rail to the faucet. One guy out of the loop zaps the rail, I was in the middle of the loop. I felt the Zap and threw my arms up in the air to break the connection, woke up on the ground.
If you draw that circuit on paper, I'm pretty sure the secondary, high voltage winding, is not grounded, the blackboard rail was not grounded. The circuit may have been behaving more like a Tesla coil, single wire path with power transmission by resonant coupling between source and the load.
Let's say the guy grabs one leg of oil burner transformer with one hand and touches a 10,000 gal steel water tank with the other hand. Let's say the steel tank is completely insulated from ground on the polystyrene foam boards. The tank would be a capacitive load with single wire connection to source.
If the guys does not get a shock from that you could tune the HV source frequency of oscillation to the resonant frequency of the tank, then he will get it.
