While doing a kitchen remodel found all circuits were fed via conduit( Florida home circa 1950s) Has a exterior 150 amp service feeding inside via pvc into exterior junction boxes to inside the house. During the demo phase could not find the other end of the conduit so I shorted them out 1 wire at a time and disconnected the feed from the inside Sq D panel.But could not pull out the wire from the conduit so I was abandoning wires as I went along.
Finally got to a pipe that had 3 pair of wires decided I am gonna find the other end so I used my hi hat cutting hole saw to make some prelininary openings found 2 in pvc feeding sq d panel. Cut 2 more holes and oh goodness I discovered a buried cb panel housing.
this is where all the conduit was ending then fed via a 2 inch pvc to sq d panel inside.
Opened up wall now find the panel has no guts and is being used as a cross connection enclosure but it has no cover. ( Sorry but I want you guys to know the full story. This panel was totally covered by 5/8ths sheetrock.
I made a temp cover out of plywood to progress on with the remodel.
Now here is the 64 million dollar question. The feed for the sq d panel is in this enclosure along with many cross connections.(about 20 pairs)
Can I cover the box with a piece of metal cut to fit.I cannot remove the box as it was fired into the wall by explosive steel pins.
The enclosure has a ground tap that is being used by the existing powered circuits.
The enclosure is 10 inchs wide by 19 1/2 inchs
tall. It is a odd size.
Plan B is pop rivet some 1/4" aluminium angle to all 4 sides and then cut a piece of aluminium to fit and hide it behind a wall hanging picture.
Plan c Is rip out this mess go get a cheap brand cb enclosure gut it out and replace the box with a cb panel gutted out with a proper access cover.Keeping in mind this is attached to a concrete wall with pins. There is 1 each 2" pvc pipe, 1 each 1+1/2" steel pipe from the exterior panel. Plus 10 pieces of 1/2" and 3 or 4 3/4" steel conduits attached to the existing carcase.
Plan D Make a cover to fit from plywood 3/4" thick and leave the cover exposed behind a picture covering the ugliness.
Any legal ideas are totally entertained.
Guys this is a winner for sure nice young couple bought this mess 2 years ago. Great neighborhood 4 blocks from the Florida Beach.
Help
Help
