I'm an engineer trying to help an electrician I've worked with for 30+years. We have a 480V, 3ph sub-panel. When he measures impedance from Neutral to Ground he gets 19 Ohms, which is too much for the equipment being powered. If he unbolts and separates the Ground bus from the enclosure (leaving the insulated Neutral bus attached), the impedance drops to 1.7 Ohms, that is wanted. If he separates the Neutral bus from the enclosure (leaving the Ground bus bolted to enclosure) then the impedance stays at 19 Ohms. Is the difference Reactance? Generally speaking, how is it normally mitigated?
