Re: improper half switced outlet?
Thanks Charlie.
It came to mind 'cause of a troubleshooting run that I made at a widow's home a few years back. The kitchen outlets were blowing circuit breakers.
The house had been rewired 30 years ago. Three duplex receptacles in the kitchen had been split wired on a 20 amp small appliance multiwire. . .two 20 amp small app circuits.
I found one circuit breaker tripped. I reset it, got a really sharp report and it tripped back, along with another breaker.
Then I noticed the original tripped breaker was not seated all the way down on the bus. I pulled it loose, and saw a lot of arc weld pits on the bus and that most of the contact on the breaker was burned away.
I analyzed the circuit and found a breakout tab on a duplex receptacle still intact.
The widow said hubby had replaced that one outlet 12 years ago and, until he died a year ago, had always taken care of the "mechanical things".
She had simply overloaded the one connected 20 amp breaker. When that breaker tripped on a running overload, she had reset all the breakers. When she came to the burned one, the one hubby had pretty much destroyed, her resetting it pushed it down enough to make contact, creating a 240 volt short and scaring the bejeebers out of her.
She actually kept the breakout tab after I removed it from the device!
Edit to clarify last sentence.
[ December 28, 2004, 02:00 PM: Message edited by: al hildenbrand ]
