I was called to a residence where the in floor electric heat will not exceed 70 degrees. I checked the amp draw and it corresponds with the listing on the cable sets. I checked resistance on the floor probe and it's within parameters.
The GFCI function on the wall stat works properly and all programming functions work.
Owner tells me that it worked fine for several years after install in 2006.
The system has not been used in a couple of years and they just tried using it a few days ago.
Any ideas on where to look next?
I don't want to spend $140 on a new stat until I can verify that'd the problem.
Incoming voltage was also verified at 122V
