Stevenfyeager
- United States, Indiana
- electrical contractor
My first time wiring an inground pool. Any site that summarizes this ? I have seen an equipotential drawing. Thank you.
I've done lots of pools and will answer questions, but it would be hard to just list everything as situations are different.My first time wiring an inground pool. Any site that summarizes this ? I have seen an equipotential drawing. Thank you.
This is just bonding all the metallic paths around the pool to create the equipotential bond. Nothing goes back to the panel or a ground rod. Now, the system grounding system will, by default, get connected via the pump motors or other equipment that requires an EGC and bonding to the pool bond. On the same token, if there happens to be no equipment for the pool (very rare), and the pool was nonconductive, you would still have to install an equipotential bond if nothing but the perimeter ring/grid and pool water is involved.I've read these, thank you. It turns out the pool person says he does the bonding and requesting inspection before pouring concrete. I read that all metal fixtures are bonded together (like ladders, etc) with #8 Cu, which he says he uses. But my question is once all metal parts are bonded together (including he says, a line buried around the pool), do you connect this conductor to anything else (like a ground rod) or is the goal to just bond all the parts together ? I know it's a stupid question, bonding is not grounding, but...
