This article identifies it as a cost saving feature,.. could print this too
http://www.edi-nc.com/edi/featured/SouthwireMCAP.asp
Quote:
As an alternative to conventional AC cable, MCAP cable yields significant benefits. To begin with, it reduces termination steps, compared to AC.
? More conductors than AC
Types AC and AC cables for health care facilities are limited to four current-carrying conductors. MCAP and HCF MCAP cables have no limits on the number of conductors in a cable. That means you may see multiple neutrals and home run cables where MCAP cable is used, even in health care facilities.
? Equipment grounding conductor capacity
The armor of MCAP cable delivers 350 percent more effective ground-fault current path capacity than AC. This is based on the UL maximum permitted armor resistance for MC and AC cables. With the addition of a green insulated grounding conductor, HCF MCAP cable meets NEC 517.13 requirements for health care facilities.
? No bushings, less support than AC
Because MCAPP and HCF MCAP cables are Type MC products, they require no anti-short bushings where the armor has been cut. For more information regarding the use of anti-short bushings, refer to NEMA?s Engineering Bulletin No. 90, ?Use of Anti-Short Bushings for Terminating Type MC Cable? (available at www.NEMA.org). In addition, they require less securing and supporting than Type AC cables. Like
conventional MC, MCAP and HCF MCAP cables need support only every six feet, compared with 4.5 feet for the AC constructions.
First Interlocked Armor Type MC Cable for Health Care Facilities
HCF MCAP cable is the first interlocked armor MC cable that meets NEC 517.13 requirements for redundant equipment grounding conductor paths in health care facilities, and, as noted above, HCF MCAP cable has a 350 percent better ground-fault current path in the armor than the armor of AC cable suitable for use in health care facilities. Figure 5 shows a comparison of HCF MCAP cable with AC cable suitable for use in health care facilities.
