There is no standard to test (And therefore rate) leather or rubber gloves, so you won't find a rating on those.
Now that being said, I friend of mine did some testing on rubber gloves to try to get an idea of how much protection they really offer.
http://www.arcwear.com/arcwear.com/downloads/Salisbury_2002-04_Glove_Test_Report.pdf
Keep in mind, this was just a lab test, there is no ASTM testing standard so these numbers don't mean squat. Even if they did, how would that help you? The Ei is calculated for a specific working distance, usually 18" based on the toro distance to the equipment being worked on, your hands will be much closer so the Ei will be exponentionaly higher than your label states.
The leather protectors for your rubber gloves are good for arc flash protection, thats why the 70E requires them. There are some arc rated gloves on the market, made from similar fabrics as your clothing, but they offer no shock protection, are very cumbersome to work in, and again, you don't know the Ei at the working distance of your hands so there is no real way to properly apply them.
