I am an electrical contractor, and I have a client who told me they plan on connecting their generator to the dryer plug in their house.
Now, besides the obvious dangers of backfeeding the panel, the generator also has the neutral and ground connected together, which means it should be a separately derived system, and the neutral in the panel should be diconnected along with the two hot conductors. Of course, the homeowner is only going to switch off the Main breaker, so the neutral will not be disconnected.
I told the homeowner this was dangerous, but when he asked me what was the worst that could happen, I drew a blank. From what I understand, this situation will not result in any extra shock danger, because any fault current will be trying to return to the source, and not to the ground.
Help me out here. What's the possible dangers of not switching the neutral in the panel?
