mattsilkwood
- missouri
does anyone have any thoughts on the validity of an ig circuit?
mattsilkwood said:but they are big in retail chains,lowes, walmart, home depot,ect.
mattsilkwood said:sorry guys i did mean isolated , but they are big in retail chains,lowes, walmart, home depot,ect. i recently did a lowes and they go so far as one pipe one circuit with an ig talk about a waste of money!
dereckbc said:That makes a little more since and I suspect I know why. Could these be used at the POS stations? For whatever reasons the POS equipment still uses signal I/O means that use ground as part of the signal path like RS-232 rather than ethernet. That being the case then they would have to use IGR, especially since all the cable distances would be extreme.
is there any code required this?LarryFine said:.....the IG is still tied to the system neutral/ground at the bonding point......
peter d said:OK, now I have foot in mouth disorder. Is there still a valid use for IG? I was under the impression that it was pretty much useless nowadays.
No there is not, that is a design issue. Code permits the IG to originate any where down stream from the N-G bond.zyhml said:is there any code required this?
Okay, not exactly in those words, but my point was that the IG EGC still eventually connects to the system neutral, via some EGC or other, due to the main bonding jumper.zyhml said:is there any code required this?
dereckbc said:For whatever reasons the POS equipment still uses signal I/O means that use ground as part of the signal path like RS-232 rather than ethernet.
In the past year or so, we have wired (both for power and networking) several POS systems, and they have all been CAT-5 and still specified IG wiring and receptacles.iwire said:That has finally seemed to go away with most new POS equipment.
(BTW - In this thread "POS" means Point Of Sale)
More of the equipment is using Cat 5, however we still have a large customer with a certain vendors coupon printer that uses a shielded cable.
LarryFine said:I comply, of course, because I'll do whatever the customer pays for (legally, of course).
The POS people specify IG, and will blame any problems on me if I don't comply.
However, nobody specifies the wiring type, so I use 12-4 MC and strip the red as the non-IG box EGC, and use the green as the IG EGC for the receptacles.
LOL, yes, that's what I meant. I was recently explaining to one of my guys that rubber cord is the only cable type where the EGC counts in the conductor quantity (as far as I know), and it caused a brain hiccup.iwire said:12/3?
It's never been an issue, and I pass 99% of my inspections on the first go-around.Anyway I have done the same thing with the red in the past but feel it almost always violates 250.119(B).
LarryFine said:It's never been an issue, and I pass 99% of my inspections on the first go-around.
