Can an indoor, non-ventilated location be classified as Class I Division 2? I would normally say no - if you classify it Div 2 then it's possible to accumulate gas, and if there is no ventilation, then the area should be Div 1. However, I am looking at NFPA 820 Figure A.4.2(d) which shows a drywell/vault physically separated from the wet well, and classifies as Div 2 if not adequately ventilated.
I'm trying to apply 820 to a landfill leachate riser building with no ventilation. Usually, there is ventilation and the building is conservatively classified Div 2. But maybe non-ventilated could be Div 2 as well?
