buck33k
- Washington state and North Carolina
680.12 requires a maintenance disconnect for indoor spas and hot tubs as well as with outdoor installations.This is for all utilization equipment other than lighting.
I have a couple of questions concerning these INDOOR spas and hot tubs and the maintence disconnect.
1. Can the main breakers in the spa or hot tub package serve as the maintenance disconnect? They are readily accessable and within sight when working on the pumps/motors etc. contained in the unit.
2. If the answer to question (1) is no, can the maintenance disconnect be remotely operated(using a snap switch)? Per the 2002 handbook 680.41, an emergency switch can be remotely operated, why not a maintenance disconnect?
Buck
Buck
