I have a question about inductors. From my observations, am I correct in assuming that
1. A ballast used in a florescent tube is to initially start the electron emission. :?
2. An ignition coil in a vehicle is used to generate high voltage sparks. :?
My favorite website below, gives an explanation of inductance. How do I relate it to the above observations? :?:
http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
"EDIT: and select inductance from side bar to read through."
I know some of you are the very best
in explaining things. I hope you will do it again.
Thanks in advance for your replies.
