Frank Bourbeau
- Goleta, CA USA
I have a 12-lead 5 hp motor that I want to use as a rotary isolation transformer. This transformer will serve as a 1:1 isolation transformer and also as a harmonic filter to clean up the distorted primary voltage. To accomplish this, I used the low voltage connections specified on page 5 of the EASA handbook but with certain connections omitted to create two isolated delta windings. This resulted in the following connections:
Pri. 1 U1&U2 Pri. 2 V1&V2 Pri. 3 W1-V2
Sec. 1 U5&U6 Sec. 1 V5&V6 Sec. 3 W5-V6
The unloaded motor runs with normal current and near-synchronous speed when connected per the EASA table (U1&U2&U5&U6, etc.). However, when the windings are connected in two isolated deltas, the motor draws high current and runs slowly when ac voltage is applied to one of the deltas.
I thought the motor would run as a normal motor with only one of the two delta windings energized. Can anyone explain why it didn't?
Frank Bourbeau, Enerpro Inc.
