I am having a problem with a starter in my plant, where after the starter has pulled in, we cannot get it to drop back out even after dropping out the necessary control contacts that feed the starter coil. In other words when we go to start the mtor, the starter pulls in fine but when we hit the stop button on the control circuit the starter stays pulled in and does not drop back out when control power is removed from the starter coil.
When we break the control circuit thus dropping the control voltage to the coil we are noticing that we are still reading 65V on the wire going to the coil. The coil is an 120V and 160VA rated coil. My question is weather or not the 65V which we believe is being caused by inductance would be enough to hold this coil in? I always thought that below 70% rated voltage a coil would not be able to stay latched.
With induction, only a voltage is induced on the wire, not current, and the current is determined by the load on the wire?? Is this correct?? What could have caused this induction to just appear out of the blue, since we have not had a problem for years until now with this circuit?
