electricalperson
- massachusetts
in school we were talking about inductive reactance on circuits. well today i decided to do an experiment at work. i was installing a relay with a 24 volt coil to control a fan. i measured resistance with the power off at the coil and got 9 ohms. the measured voltage off the transformer located a couple inches away was 23.8 volts using ohms law i = e/r i get 2.64 amps. then i put my meter in series with the coil and measure .3 amps. using ohms law again R = E/I i get 79.3 ohms. was i measuring the effects of inductive reactance on ac inductive circuits?
