kbsparky
- Delmarva, USA
Today, one of my customers experienced a short power outage, probably for a second or less. It appears that this outage and the surge that followed fried a computer module in one of his machines. This is the second time one of these modules was cooked as an apparent result of a short-duration outage.
These modules ain't cheap: $3200 or so each. This particular machine has about 6 of `em in there, and he wants to do something to protect them better.
Since the high-tension lines out on the road are overhead, and pass through wooded areas, things like high winds can cause the trees to momentarily hit the lines, and make the power blink, flicker, and so forth. I figure when this happens, there is also a surge associated with the event, and this can cause the damages he is experiencing. Sometimes, when such blinking occurs, the power restores itself with one phase left dead. (I figure there may be a dead squirrel or buzzard out there as a result
The service is a 3-phase 240 Volt open-bank delta connected, 400 Amp. The piece of equipment has its own 100 Amp feeder circuit, connected to its internal computer system, controlling various motors, servos, solenoids, etc.
At first, I thought about maybe trying to isolate the internal computer from the rest of the equipment, and using a UPS/APC unit might keep the computer up and running. But, it is integrated into the equipment and functions that isolating it may not be feasible. The servo/modules that got fried are connected to all 3 phases, so this is not your ordinary computer system.
So, I figured that installing a power-conditioning surge unit at the service panel should be able to help. I have outlined the service voltage and size to one of my suppliers looking for price/availability of an appropriate unit. These are probably capacitor bank/MOV units?
Do any of you have experience in dealing with this type of problem?
